duncangray
| [Solved]Serial Interrupt isn't working |
Posted: Thu Sep 05, 2013 3:42 pm |
I must be doing something very stupid as I can echo characters using a polled routine (tx & rx using realterm)
| Code: | #include "18f87k22.h"
#fuses HSH ,PLLEN, NOWDT, NOPROTECT // , NOLVP
#use delay(clock=58982400)
//#use rs232 (baud=19200, xmit=PIN_C6, rcv=PIN_C7, PARITY=N, BITS=8)
#use rs232 (baud=19200, xmit=PIN_G1, rcv=PIN_G2, PARITY=N, BITS=8)
do {
putc( getc() );
} while (TRUE); // END OF MAIN LOOP
but when I try to use #int_rda
#int_rda
void serial_isr() {
putc( getc() );
enable_interrupts(INT_RDA);
do {
delay_ms(10000);
it doesn't work. What am I missing?
Thanks all.
Duncan
