[Solved]Serial Interrupt isn't working
duncangray
PostPosted: Thu Sep 05, 2013 3:42 pm     Reply with quote
I must be doing something very stupid as I can echo characters using a polled routine (tx & rx using realterm)
#include "18f87k22.h"
#fuses HSH ,PLLEN, NOWDT, NOPROTECT   // , NOLVP
#use delay(clock=58982400)
//#use rs232 (baud=19200, xmit=PIN_C6, rcv=PIN_C7, PARITY=N, BITS=8)
#use rs232 (baud=19200, xmit=PIN_G1, rcv=PIN_G2, PARITY=N, BITS=8)
   do {
        putc( getc() );
   } while (TRUE); // END OF MAIN LOOP
but when I try to use #int_rda
#int_rda
void serial_isr() {
   putc( getc() );
   enable_interrupts(INT_RDA);
   do {
      delay_ms(10000);
it doesn't work. What am I missing?
Thanks all.
Duncan
PostPosted: Thu Sep 05, 2013 3:56 pm     Reply with quote
See this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=49148
duncangray
PostPosted: Thu Sep 05, 2013 4:10 pm     Reply with quote
Thanks PCM programmer. You are quite correct.
I was having problems with the polled version on C6, C7 as well but that must be hardware.
Thanks again for your rapid help.
Duncan
