I am using a PIC32MX795F512L in device mode but cannot get it to connect.
So here is a step by step of what is happening to aid with any help people can give.
Before i attach USB cable:
3.3v at Vusb (RF6)
3.3v at Vbus (RF7)
0V at D+ (RG2)
0V at D- (RG3)
After i attach USB
3.7v at Vusb (RF6)
5v at Vbus (RF7)
0V at D+ (RG2)
0V at D- (RG3)
I am unsure why Vusb is getting a voltage increase when it is attached to nothing but a capacitor and 3.3v
The computer is not recognizing that a device is attached and D+ and D- show no activity on oscilloscope
My setup is as follows:
VCC (pin 1) -> vbus (RF7) with 4.7uF cap
GND (pin 4) -> GND
D+ (pin 3) -> RG2
D- (pin 2) -> RG3
3.3v via 100nF cap to Vusb (RF6)
Wire from Vcc to RB5 to trigger USB_BUS_SENSE
i am using interrupt mode and the main part of my code can be seen below
#if defined(USE_USB_BUS_SENSE_IO)
tris_usb_bus_sense = INPUT_PIN; // See HardwareProfile.h
#endif
#if defined(USE_SELF_POWER_SENSE_IO)
tris_self_power = INPUT_PIN; // See HardwareProfile.h
#endif
UserInit();
USBDeviceInit(); //usb_device.c. Initializes USB module SFRs and firmware
//variables to known states.
}//end InitializeSystem
void USBDeviceAttach(void)
//if we are in the detached state
if(USBDeviceState == DETACHED_STATE)
if(USB_BUS_SENSE == 1)
//Initialize registers to known states.
U1CON = 0;
// Mask all USB interrupts
U1IE = 0;
//Configure things like: pull ups, full/low-speed mode,
//set the ping pong mode, and set internal transceiver
SetConfigurationOptions();
USBEnableInterrupts(); //Modifies global interrupt settings
// Enable module & attach to bus
while(!U1CONbits.USBEN){U1CONbits.USBEN = 1;}
//moved to the attached state
USBDeviceState = ATTACHED_STATE;
Theses are the main snippets of code i believe to be important to get it to connect. Is there any reason why my PC does not recognise my device at all.
Posted: Thu Jan 30, 2014 1:42 am
That is the MicroChip USB stack, not CCS. Go and ask in their forum.
