USB not recognised by computer
BM92
PostPosted: Wed Jan 29, 2014 1:46 pm     Reply with quote
I am using a PIC32MX795F512L in device mode but cannot get it to connect.
So here is a step by step of what is happening to aid with any help people can give.
Before i attach USB cable:
3.3v at Vusb (RF6)
3.3v at Vbus (RF7)
0V at D+ (RG2)
0V at D- (RG3)
After i attach USB
3.7v at Vusb (RF6)
5v at Vbus (RF7)
0V at D+ (RG2)
0V at D- (RG3)
I am unsure why Vusb is getting a voltage increase when it is attached to nothing but a capacitor and 3.3v
The computer is not recognizing that a device is attached and D+ and D- show no activity on oscilloscope
My setup is as follows:
VCC (pin 1) -> vbus (RF7) with 4.7uF cap
GND (pin 4) -> GND
D+ (pin 3) -> RG2
D- (pin 2) -> RG3
3.3v via 100nF cap to Vusb (RF6)
Wire from Vcc to RB5 to trigger USB_BUS_SENSE
i am using interrupt mode and the main part of my code can be seen below
int main(void)
    InitializeSystem();
    USBDeviceAttach();
        ProcessIO();
    }//end while
}//end main
static void InitializeSystem(void)
    AD1PCFG = 0xFFFF;
    SYSTEMConfigPerformance(60000000);
    #if defined(USE_USB_BUS_SENSE_IO)
    tris_usb_bus_sense = INPUT_PIN; // See HardwareProfile.h
    #if defined(USE_SELF_POWER_SENSE_IO)
    tris_self_power = INPUT_PIN;   // See HardwareProfile.h
    UserInit();
    USBDeviceInit();   //usb_device.c.  Initializes USB module SFRs and firmware
                   //variables to known states.
}//end InitializeSystem
void USBDeviceAttach(void)
    //if we are in the detached state
    if(USBDeviceState == DETACHED_STATE)
        if(USB_BUS_SENSE == 1)
           //Initialize registers to known states.
            U1CON = 0;
            // Mask all USB interrupts
            U1IE = 0;
            //Configure things like: pull ups, full/low-speed mode,
            //set the ping pong mode, and set internal transceiver
            SetConfigurationOptions();
            USBEnableInterrupts();  //Modifies global interrupt settings
            // Enable module & attach to bus
            while(!U1CONbits.USBEN){U1CONbits.USBEN = 1;}
            //moved to the attached state
            USBDeviceState = ATTACHED_STATE;
Theses are the main snippets of code i believe to be important to get it to connect. Is there any reason why my PC does not recognise my device at all.
PostPosted: Thu Jan 30, 2014 1:42 am     Reply with quote
That is the MicroChip USB stack, not CCS. Go and ask in their forum.
