Joined: 10 Dec 2011 Posts: 376 Location: Sofiq,Bulgariq
Double interrupt doesnt work
Posted: Wed Dec 11, 2013 3:37 am
Hello Guys! I am trying to create a code that should respond on two pin interrupt H2L edge.The first interrupt is INT_RB7_H2L and second one is INT_RA5_H2L. The problem is that only one works, depends on which one has bigger priority. I simplified the code for easily understanding the issue.
Here is the code:
Sorry for bad English!
Thanks in advance! _________________ A person who never made a mistake never tried anything new.
Posted: Wed Dec 11, 2013 9:38 am
The compiler clears the physical interrupt for you - so get rid of the line doing this.
However what it doesn't do is clear the IOCB flags. These are a set of flags to say 'which pin' triggered the interrupt.
