Double interrupt doesnt work
rikotech8
PostPosted: Wed Dec 11, 2013 3:37 am     Reply with quote
Hello Guys! I am trying to create a code that should respond on two pin interrupt H2L edge.The first interrupt is INT_RB7_H2L and second one is INT_RA5_H2L. The problem is that only one works, depends on which one has bigger priority. I simplified the code for easily understanding the issue.
Here is the code:
#include <16F1508.h>
#fuses NOWDT,NOMCLR,INTRC_IO
#use delay(clock=16M)
#define valves pin_c5
#PRIORITY INT_RA,INT_RB
#INT_RA
   void dec_button()
         if (!input(pin_A5))
               output_high(valves);
      clear_interrupt(INT_RA5_H2L);
#INT_RB
   void inc_button()
         if(!input(pin_b7))
               output_low(valves);
      clear_interrupt(INT_RB7_H2L);
   ENABLE_INTERRUPTS(INT_RA5_H2L);
   ENABLE_INTERRUPTS(INT_RB7_H2L);
   ENABLE_INTERRUPTS(GLOBAL);
   while(true)
Sorry for bad English!
Thanks in advance! Very Happy
A person who never made a mistake never tried anything new.
PostPosted: Wed Dec 11, 2013 9:38 am     Reply with quote
The compiler clears the physical interrupt for you - so get rid of the line doing this.
However what it doesn't do is clear the IOCB flags. These are a set of flags to say 'which pin' triggered the interrupt.
Add this:
#byte IOCAF = 0x393
#byte IOCBP = 0x394
#define clear_IOCA_flags() IOCAF = 0
#define clear_IOCB_flags() IOCBF = 0
and call these functions (IOCA for INT_RA, and IOCB for INT_RB), instead of the clear_interrupt line.
So:
#INT_RA
void dec_button(void)
     if (!input(pin_A5))
     clear_IOCA_flags();
