PIC10f204 configuration
kbruin79
PostPosted: Sun Mar 31, 2013 11:50 pm     Reply with quote
I am trying to get a simple code running on a PIC10f204 to flash an LED. This is always my first step to make sure the GPIO pins are functioning properly. I wrote this code and unfortunately the PIC output GP1 pin never worked. Here is the code, any idea what I am missing ? I appreciate your comments. Thanks
#include <10f204.h>
#use delay (CLOCK=4000000) //(clock=4M)
#fuses NOWDT, NOMCLR, NOPROTECT
#byte CMCON0 = 7
#bit  CMCON0_3=CMCON0.3
//Turn off comparator
CMCON0_3=0;
while(1){
   OUTPUT_HIGH(PIN_B1);
   OUTPUT_LOW(PIN_B1);
PostPosted: Mon Apr 01, 2013 3:13 pm     Reply with quote
first observations would be
1) *MCLR tied high ? or disabled ??
2) GP1 is used for programming, is it 'removed' from that when testing?
3) proper bit set to disable the comparator?
4) version of compiler issues ??
5) tested good LED ? Heck I've bought bad 'new' ones before ??
report back....
hth
jay
kbruin79
PostPosted: Mon Apr 01, 2013 4:29 pm     Reply with quote
Thanks for the reply, see my answers below.
MCLR set as input. So it's disabled
Yes it's removed from the programing circuit when tested
Yes, 3rd bit in the CMCON0 disables the comparator.
CMCON0_3=0;
It's either 4.16 or 4.19 but I will check when I get home
I checked that too, LED is working.
report back....
hth
jay
kbruin79
PostPosted: Tue Apr 02, 2013 10:56 am     Reply with quote
Problem fixed, it was a programer issue. Thanks !
