kbruin79
| PIC10f204 configuration |
Posted: Sun Mar 31, 2013 11:50 pm |
I am trying to get a simple code running on a PIC10f204 to flash an LED. This is always my first step to make sure the GPIO pins are functioning properly. I wrote this code and unfortunately the PIC output GP1 pin never worked. Here is the code, any idea what I am missing ? I appreciate your comments. Thanks
#include <10f204.h>
#use delay (CLOCK=4000000) //(clock=4M)
#fuses NOWDT, NOMCLR, NOPROTECT
#byte CMCON0 = 7
#bit CMCON0_3=CMCON0.3
//Turn off comparator
CMCON0_3=0;
while(1){
OUTPUT_HIGH(PIN_B1);
OUTPUT_LOW(PIN_B1);
Joined: 01 Jul 2010 Posts: 9637 Location: Greensville,Ontario
Posted: Mon Apr 01, 2013 3:13 pm |
first observations would be
1) *MCLR tied high ? or disabled ??
2) GP1 is used for programming, is it 'removed' from that when testing?
3) proper bit set to disable the comparator?
4) version of compiler issues ??
5) tested good LED ? Heck I've bought bad 'new' ones before ??
report back....
hth
jay |
kbruin79
Posted: Mon Apr 01, 2013 4:29 pm |
Thanks for the reply, see my answers below.
| temtronic wrote: | first observations would be
MCLR set as input. So it's disabled
Yes it's removed from the programing circuit when tested
Yes, 3rd bit in the CMCON0 disables the comparator.
CMCON0_3=0;
It's either 4.16 or 4.19 but I will check when I get home
I checked that too, LED is working.
report back....
hth
jay |
kbruin79
Posted: Tue Apr 02, 2013 10:56 am |
| Problem fixed, it was a programer issue. Thanks ! |
