Bootloader example don't compile
rikotech8
PostPosted: Sun Mar 10, 2013 11:56 am     Reply with quote
Hello!
I'm trying to create bootloader by modifying the example provided by CCS but I get an error at one of the loader.c lines.
Here is the code I made:
#include <16F873A.h>
#use delay(clock=16000000)
#use rs232(baud=9600, xmit=PIN_C2, rcv=PIN_C3,ERRORS)
#include <bootloader.h>
#include <loader.c>
#org LOADER_END+1,LOADER_END+10
void application(void) {
  while(TRUE);
#org 0x20,0x3F
void main(void) {
   if(!input(PIN_B5))
      load_program();
   application();
#ORG default
#int_global
void isr(void) {
   jump_to_isr(LOADER_END+5*(getenv("BITS_PER_INSTRUCTION")/8));
The line of the error is
#ORG LOADER_ADDR+10, LOADER_END auto=0 default
(this line is in loader.c the driver I have inserted)
The error I get is : Invalid ORG range
Where I'm wrong?
A person who never made a mistake never tried anything new.
PostPosted: Sun Mar 10, 2013 6:45 pm     Reply with quote
Have you actually got the examples supplied by CCS to compiler and execute correctly?
jeremiah
PostPosted: Sun Mar 10, 2013 7:50 pm     Reply with quote
You have 2 #org statements that have overlapping addresses. You can see that by comparing the #org in your code with the one in the error line. You should probably take a step back and really make sure you know where things go. From my own experience, a large % of bootloader problems come from stuff not placed in the right address locations.
rikotech8
PostPosted: Mon Mar 11, 2013 2:32 am     Reply with quote
Thank you guys!
I saw my mistake was not using complete example bootloader.c
Now the code compiles fine!
New bootloader code is:
#use delay(clock=16M)
#define _bootloader
#include <loader.c>
  while(TRUE);
#org 0x20,0x3F
void main(void) {
   if(!input(PIN_B5))
      printf("Ready...");
      load_program();
   application();
#ORG default
#int_global
void isr(void) {
The code to send:
   char c;
   while (true)
      c = getc();
      putc(c);
How to send my second code. I guess I need special software for my PC.
I tried to use this one http://www.etc.ugal.ro/cchiculita/software/picbootloader.htm
but it can't establish communication with my PIC. Apparently I need another software.
I have heard that I can use hyperterminal, or Serial Input/Output Monitor(siow provided by CCS), but I don't know how to load the hex file to be send.
Thank you in advance!
