rikotech8
Joined: 10 Dec 2011 Posts: 376 Location: Sofiq,Bulgariq
Bootloader example don't compile |
Posted: Sun Mar 10, 2013 11:56 am |
Hello!
I'm trying to create bootloader by modifying the example provided by CCS but I get an error at one of the loader.c lines.
Here is the code I made:
#include <16F873A.h>
#use delay(clock=16000000)
#use rs232(baud=9600, xmit=PIN_C2, rcv=PIN_C3,ERRORS)
#include <bootloader.h>
#include <loader.c>
#org LOADER_END+1,LOADER_END+10
void application(void) {
while(TRUE);
#org 0x20,0x3F
void main(void) {
if(!input(PIN_B5))
load_program();
application();
#ORG default
#int_global
void isr(void) {
jump_to_isr(LOADER_END+5*(getenv("BITS_PER_INSTRUCTION")/8));
The line of the error is
Code: | #ORG LOADER_ADDR+10, LOADER_END auto=0 default |
(this line is in loader.c the driver I have inserted)
The error I get is : Invalid ORG range
Where I'm wrong? _________________ A person who never made a mistake never tried anything new. |
Joined: 01 Jul 2010 Posts: 9167 Location: Greensville,Ontario
Posted: Sun Mar 10, 2013 6:45 pm |
Have you actually got the examples supplied by CCS to compiler and execute correctly? |
jeremiah
Posted: Sun Mar 10, 2013 7:50 pm |
You have 2 #org statements that have overlapping addresses. You can see that by comparing the #org in your code with the one in the error line. You should probably take a step back and really make sure you know where things go. From my own experience, a large % of bootloader problems come from stuff not placed in the right address locations. |
rikotech8
Posted: Mon Mar 11, 2013 2:32 am |
Thank you guys!
I saw my mistake was not using complete example bootloader.c
Now the code compiles fine!
New bootloader code is:
#use delay(clock=16M)
#define _bootloader
#include <loader.c>
while(TRUE);
#org 0x20,0x3F
void main(void) {
if(!input(PIN_B5))
printf("Ready...");
load_program();
application();
#ORG default
#int_global
void isr(void) {
The code to send:
char c;
while (true)
c = getc();
putc(c);
How to send my second code. I guess I need special software for my PC.
I tried to use this one http://www.etc.ugal.ro/cchiculita/software/picbootloader.htm
but it can't establish communication with my PIC. Apparently I need another software.
I have heard that I can use hyperterminal, or Serial Input/Output Monitor(siow provided by CCS), but I don't know how to load the hex file to be send.
Thank you in advance! _________________ A person who never made a mistake never tried anything new. |
