If I close the PCW HD 4.14 compiler, disconnect the ICD-U64 programmer, then restart the program and reconnect the ICD-U64 programmer, I can program the unit 2 - 3 times before the same problem begins again. Any thoughts?
Posted: Tue Feb 26, 2013 6:54 pm
I'm not sure how closely related they are, but I am using a PIC24F32KA304 (and 302). I've found the most recent ICD-U64 firmware doesn't work well with those chips, so I found an older revision (I want to say rev 2.87) and haven't found any issues.
I would suggest contacting CCS support and letting them know. They are generally very helpful with things like this.
