Problem with SPI protocol for the counter LS7366R
romfisch
PostPosted: Sun May 05, 2013 7:17 am     Reply with quote
I'm trying to communicate in SPI with the counter LS7366R, but it doesn't work.
So I do a test :
1) First, in the function Init_L7366R I initialize the registers MDR0 and MDR1.
2) Secondly, every 2 seconds, I ask the counter to give me the value of the register MDR1.
3) Finally the Pic send me this value (via RS232).
I did a test and the RS232 is OK. But I always get the value Ox00 when the pic should send me the value OxC3.
#include <16F876A.h>
#include <stdio.h>         //Librairie standard (x: printf, scanf, etc...)
#include <stdlib.h>         // Librairie pour la fonction abs
#USE DELAY (clock = 20000000)      // Frequence horloge = 20Mhz
#FUSES NOWDT,HS, PUT, NOPROTECT, BROWNOUT, NOLVP, NOCPD, NOWRT, NODEBUG
#use rs232(baud=9600, parity=N, xmit=PIN_C6, rcv = PIN_C7, bits=8, stop=1)
// Voir s'il faut faire un : #use spi  (options=) !!!!
// Les defines (en majuscules car directive pré-processeur):
#define SS PIN_C0      // Pin de selection du slave
#define SDO PIN_C5      //
#define SDI PIN_C4
#define SCK PIN_C3
#define LED_DEBUG1 PIN_A0
#define LED_DEBUG2 PIN_A5
#define ENABLE PIN_C1
#define IN_A PIN_A2
#define IN_B PIN_A1
//----------Variables LS7366R-------------------------
#define WR_MDR0 0x88   // Registre qui configure le mode de quadrature, le mode de comptage et le mode d'indexage
#define WR_MDR1   0x90   // Registre qui configure la taille du compteur et l'utilisation des flags.
#define CONF_MDR0 0x01   // [0000 0001] : b7=FilterClockDivisionFactor|
#define CONF_MDR1 0xC3   // [1100 0011] : b7=Flag_on_Carry |b6=Flag_on_Borrow|b5=NOP|b4=NOP|b3=Not_Used|b2==Enable_Couting|b1b0=1-Byte_counter_Mode
#define LOAD_OTR 0xE8   // Transfer CTNR to OTR in "parallel" : permet ensuite de lire OTR sans perturber le comptage !
#define READ_OTR 0x68   // Une fois le contenu de CNTR transféré dans OTR, on lit OTR.
#define READ_STR 0x70   // STR registre d'info sur l'état du compteur : b7=carry |b6=Borrow| b5=CMP| b4=INDEX_LATCH| b3=CEN|b2=PLS| b1=Conut_Direction_Indecator| b0=Sign_Bit
#define CLEAR_STR 0x30
#define CLEAR_CTR 0x20
#define READ_CTR 0x60
#define READ_MDR0 0x48
#define READ_MDR1 0x50
#bit BF =  0x94.0      // Bit 0 du registre SSPSTAT : 0 : pas de donnée dans SSPBUF // 1 : Il y a une donnée dans SSPBUF
#bit SMP = 0x94.7      // Bit 7 du registre SSPSTAT : Détermine a quel moment du cycle d'horloge on effectue la capture du bit sur SDI (0: Milieu | 1 : Fin)
#bit CKE = 0x94.6      // Bit 6 du registre SSPSTAT : Détermine que sens de transistion d'horloge accompagne le placement du bit sur SDO (0 : Repos -> Actif)
#bit CKP = 0x14.4      // Bit 4 du registre SSPCON : Donne le niveau de l'etat de repos (0 : Etat de repos = Etat Bas | 1 : Etat de repos = Etat Haut)
#bit SSPEN = 0x14.5      // Bit 5 du registre SSPCON : 1 = Mise en route du module SSP
#bit WCOL = 0x14.7      // Bit 7 du registre SSPCON : 1 = on a essayé d'écrire dans SSPBUF (pour envoyer un nv octet) alors que le transfer de l'octet précédent n'est pas encore envoyé
#byte SSPBUF = 0x13
#int_RDA      // Interruption rs232
void RDA_isr()
      char recu;
   recu = getchar();
   putchar(recu);
   output_toggle(LED_DEBUG2);
   if (recu==0x65)
      output_toggle(LED_DEBUG1);
//Prototypes des fonctions :
char Lire_Data(char);
void Init_L7366R(void);
// Déclaration des variables locales au Main :
   int compteur=1;
   port_b_pullups(TRUE);         //Resistance PullUp du port B
    output_bit(ENABLE,0);          // Désactive le L6203
// Initilisation :
   output_bit(LED_DEBUG1,1);   // Les diodes de Debug sont utilisées pour repérer un eventuel reset du Pic
   output_bit(LED_DEBUG2,1);
   delay_ms(2000);               // Petite tempo pour laisser le temps à l'alim de se stabiliser.
   output_bit(LED_DEBUG1,0);      // Les diodes de Debug sont utilisées pour repérer un eventuel reset du Pic
   output_bit(LED_DEBUG2,0);
   setup_adc_ports(NO_ANALOGS) ; // Toutes les pins du ports A sont en digital
// Reglage des Timers :
   setup_timer_2 (T2_DIV_BY_1, 200, 1);    // Prédiviseur=1|PR2=200(->F_PWM=25KHz)|Postdiviseur=1, mais on s'en fout pour le PWM
// Direction des ports : (1 = Entrée; 0 = Sortie)
   SET_TRIS_A( 0b000000);         //  *
   SET_TRIS_B( 0b00000000);      //  *
   SET_TRIS_C( 0b10010000);      //  RC4=entrée, car SDI| RC7=entrée, car RX
// Mise en route du module SPI
   setup_spi(spi_master |spi_l_to_h | SPI_CLK_DIV_64 ); // En mode master| On completera par CKE et CKP | F_SPI = F_cycle /16 = 5MHz / 16 = 312.5 kHz
   CKP =0;      // Etat de repos = Etat Bas (0)
   CKE=1;       // Le master met sa donnée lors de la transition : Etat de Repos --> Etat Actif
   SMP = 0;   // Le master lit sa donnée en milieu du cycle (car le slve place sa donnée en début de cycle. cf son Datasheet)
//Autorisation des interruptions :
   enable_interrupts(INT_RDA);         // Autorise les interruptions rs232
      enable_interrupts(GLOBAL);          // Autorisation globale des interruptions
   output_bit(IN_B,1);             // on compte dans le sens positif
   Init_L7366R();   // On configure les registres MDR0 et MDR1 du LS7366R
   output_bit(SS,1);               // Deselectionne le slave
while (1)
   delay_ms(2000);
   compteur = Lire_Data(READ_MDR1);
   putchar (compteur);
char donnee;
   output_bit(SS,1);
   delay_ms(1);
   output_bit(SS,0);         // Selectionne le Slave
   delay_us(1);             // tempo de 1 us (datasheet dit 120 ns)
   SPI_write(WR_MDR0);       // On veut configurer MDR0
   while(!spi_data_is_in()){}   // On boucle tant qu'on n'a rien reçu dans SSPBUF (<=> Fin de com)        <==ON POURRAIT EGALEMENT TESTER SSPSTAT,BF==>
   donnee =spi_read();       // On lit la donnée pour effacer le Flag SSPSTAT,BF
   SPI_write(CONF_MDR0);       // On envoie la config de MDR0
   WCOL =0;
   output_bit(SS,1);
   delay_ms(1);
   SPI_write(WR_MDR1);       // On veut configurer MDR1
   SPI_write(CONF_MDR1);       // On envoie la config de MDR0
   WCOL=0;
char Lire_Data(char op_code)
   char donnee_slave;         // Attention à la taile de la variable selon la config du compteur du LS7366R
   output_bit(SS,1);
   delay_ms(1);
   SPI_write(op_code);       // Envoie la commande
   donnee_slave =spi_read();    // On lit la donnée pour effacer le Flag SSPSTAT,BF
   SPI_write(0x00);          // Envoie une "dummy" donnée pour lire la donnée envoyée par le Slave
   return donnee_slave;
Someone could tell me where I do a error ?
For information here is the datasheet of the counter
http://www.lsicsi.com/pdfs/Data_Sheets/LS7366R.pdf
My version of the compiler is : 4.013
I thank you per advance for your help.
Romain
PostPosted: Sun May 05, 2013 10:42 am     Reply with quote
Your program is complex and it could be much more simple.
But first,
1. What is the Vdd voltage of the PIC and of the LS7366 ?
Are they both 5v ? Or is there a different Vdd voltage on each chip?
2. Post a list of the SPI pin connections between the PIC and the LS7366.
Post the pin numbers, not the pin names.
romfisch
PostPosted: Mon May 06, 2013 12:44 am     Reply with quote
and thank you for your answer.
I find my error : There was an error on the connections between the Pic and the counter.
Now it works !
Romain
hasimi20
PostPosted: Wed Jul 03, 2013 12:05 am     Reply with quote
hi romfisch,
gonna try your program!
