gpsmikey
Renewed CCS PCWH - which version of mplab under W7/64 ? |
Posted: Wed Aug 01, 2012 6:50 pm |
Just upgraded/renewed my PCWH compiler to install on my new windows 7/64 partition - anybody have any comments on which version of MPLAB works best with it ? (or is it simply the "latest version"? from Microchip (not X)). Under XP Pro, I had it working fine a year ago, but that was an older version of the compiler 4.114 and an older MPLAB on a 32 bit OS). Any words of wisdom appreciated
mikey _________________ mikey
Gabriel
Posted: Thu Aug 02, 2012 2:29 pm |
I'm using 8.86 on win 7x64. no issues except that my Pickit 3 was not being recognized....
turned out to be two preinstalled DELL apps... accuweather and Dell stage.
G. _________________ CCS PCM 5.078 & CCS PCH 5.093 |
gpsmikey
Posted: Thu Aug 02, 2012 3:08 pm |
OK, thanks. Installed 8.86 and it seems to be fine. Did run into an issue with the compiler not being able to write to an old project file, but I think that is a windows 7 thing and will research that (I am the same "user" on both partitions XP and W7, however the SSID is different as expected and for some reason, files that I have not had a problem doing things with the compiler says it can't write to them until I go in and change the file security to my name as well as all users (I have admin)). Thanks for the feedback
