I want to connect 16X2 LCD and 4X3 keypad. After including the LCD.C and KBD.C file. Where should I made changes in pin configuration. In these drivers or in main C file.
Mike Walne
Posted: Sun Jun 24, 2012 1:37 pm
Please give us some more clues.
I suggest you read the CCS forum guide.
Tell us which PIC, compiler version etc.
Mike
Posted: Sun Jun 24, 2012 3:47 pm
Where should I made changes in pin configuration ? In these drivers or in main C file ?
You make them in the main C file, and place the #define statements
above the #include line for the driver file.
Preferably you should put the keypad on PortB, which has internal
pull-up resistors which you can enable (as shown in the link).
Put the LCD on some other port, such as PortD.
