KBD and LCD!
ADeshmukh
KBD and LCD!
PostPosted: Sun Jun 24, 2012 6:00 am     Reply with quote
I want to connect 16X2 LCD and 4X3 keypad. After including the LCD.C and KBD.C file. Where should I made changes in pin configuration. In these drivers or in main C file.
Mike Walne
PostPosted: Sun Jun 24, 2012 1:37 pm     Reply with quote
Please give us some more clues.
I suggest you read the CCS forum guide.
Tell us which PIC, compiler version etc.
Mike
PostPosted: Sun Jun 24, 2012 3:47 pm     Reply with quote
Where should I made changes in pin configuration ? In these drivers or in main C file ?
You make them in the main C file, and place the #define statements
above the #include line for the driver file.
See my comments in this thread, which shows how to do it for the CCS
lcd.c driver file:
http://www.ccsinfo.com/forum/viewtopic.php?t=47663
See my comments in this thread, which shows how to edit your main
source file to set the i/o Port (PortB or PortD) for kbd.c:
http://www.ccsinfo.com/forum/viewtopic.php?t=44403&start=18
Preferably you should put the keypad on PortB, which has internal
pull-up resistors which you can enable (as shown in the link).
Put the LCD on some other port, such as PortD.
