LCD Display NHD-C0216CZ
rikotech8
PostPosted: Mon Mar 26, 2012 11:43 am     Reply with quote
Hello everyone!
For very first time I need to create a driver for this type of display. The difference at this display is that the interface driving this device is SPI or I2C, not a driver to include in my program. I intend to use SPI communication. So I don't know how to initialize the display. If someone ever works with that type of display I would be very thankful to give me some example code or reference.
Excuse my bad english!
Thx in advance!
PostPosted: Mon Mar 26, 2012 1:40 pm     Reply with quote
You didn't post the full part number of the lcd. Just searching with Google
for NHD-C0216CZ gives this data sheet:
http://www.newhavendisplay.com/specs/NHD-C0216CZ-NSW-BBW-3V3.pdf
The data sheet has pseudo-code for a driver on page 10.
You could translate this to CCS.
There is a driver flow-chart and pseudo-code on pages 33-34 here:
http://www.newhavendisplay.com/app_notes/ST7032.pdf
rikotech8
PostPosted: Tue Mar 27, 2012 2:44 am     Reply with quote
Ok but I met some problems with understanding the notion like:
void init() //not this one
//initialize the LCD //not this one
P3 = 1; //P3?
P1 = 1; //P1?
SI=1; //likely, Serial Input?
what is that mean P3=1; or P1=1 or SI=1;
What those notions means in that algorithm?
I have read the whole datasheet and i'm aware about interface communication.
I hope you understand my problem.
PostPosted: Tue Mar 27, 2012 1:50 pm     Reply with quote
The P1 and P3 lines are likely some setup code for the i/o ports on
the 8051 microcontroller. You can ignore those lines.
SI is the serial input pin to the lcd. You can use output_low(SI)
and output_high(SI) for those lines.
rikotech8
PostPosted: Wed Mar 28, 2012 1:20 pm     Reply with quote
Thank you!
