Joined: 10 Dec 2011 Posts: 376 Location: Sofiq,Bulgariq
LCD Display NHD-C0216CZ
Posted: Mon Mar 26, 2012 11:43 am
Hello everyone!
For very first time I need to create a driver for this type of display. The difference at this display is that the interface driving this device is SPI or I2C, not a driver to include in my program. I intend to use SPI communication. So I don't know how to initialize the display. If someone ever works with that type of display I would be very thankful to give me some example code or reference.
Excuse my bad english!
Thx in advance!
Posted: Mon Mar 26, 2012 1:40 pm
You didn't post the full part number of the lcd. Just searching with Google
for NHD-C0216CZ gives this data sheet:
http://www.newhavendisplay.com/specs/NHD-C0216CZ-NSW-BBW-3V3.pdf
The data sheet has pseudo-code for a driver on page 10.
You could translate this to CCS.
what is that mean P3=1; or P1=1 or SI=1;
What those notions means in that algorithm?
I have read the whole datasheet and i'm aware about interface communication.
I hope you understand my problem.
Posted: Tue Mar 27, 2012 1:50 pm
The P1 and P3 lines are likely some setup code for the i/o ports on
the 8051 microcontroller. You can ignore those lines.
SI is the serial input pin to the lcd. You can use output_low(SI)
and output_high(SI) for those lines.
rikotech8
