Current measurement
exodia505
Current measurement
PostPosted: Sun Mar 04, 2012 9:44 am     Reply with quote
Hello!
what's the best way to measure current with pic ?
NOway!!
asmboy
PostPosted: Sun Mar 04, 2012 10:07 am     Reply with quote
it all depends on:
1- AC?
2-DC?
3-the RANGE ?( 1 ua is very different from 100A )
4- and if AC - the FREQUENCY range
exodia505
PostPosted: Sun Mar 04, 2012 10:10 am     Reply with quote
i meant DC current (0-5A)
NOway!!
asmboy
PostPosted: Sun Mar 04, 2012 10:27 am     Reply with quote
Hi side or low side sensing -or floating?
Whats the CIRCUIT you intend to use this with ??
Even with an optimum circuit,
keep in mind that with a 10 bit A/d pic
you can only resolve to 7.8 ma increments and 1.95 ma with a 12 bit PIC.
The circuit you will need depends on the answer you give to the first line of this message.
BTW: for real product - or school project??
gpsmikey
PostPosted: Sun Mar 04, 2012 10:35 am     Reply with quote
Contact or non-contact (can you insert a sense resistor in-line with the load or do you have to not modify the wiring) ? What kind of frequency response do you need ? (there is DC then there is "fluctuating DC" where you are monitoring a load for example). What kind of voltage drop can you tolerate across the sensor ? To "measure current" you first have to define the requirements of what sort of "intrusion" into the circuit you want to measure can be tolerated.
mikey
mikey
SherpaDoug
PostPosted: Mon Mar 05, 2012 12:52 pm     Reply with quote
Look at these chips for high side current sensing:
http://datasheets.maxim-ic.com/en/ds/MAX4373-MAX4375.pdf
Mike Walne
Where are you sensing?
PostPosted: Tue Mar 06, 2012 3:37 am     Reply with quote
Is your current unipolar?
You said 0-5A, but could the current change direction? (i.e. -5A - 0 - +5A)
Where abouts in your circuit are you wanting to measure? (0V lead, above VDD, below VSS, floating)
Do you need a Hall effect probe?
And on and on .........
Mike
