exodia505
Current measurement |
Posted: Sun Mar 04, 2012 9:44 am |
Hello!
what's the best way to measure current with pic ? _________________ NOway!! |
Posted: Sun Mar 04, 2012 10:07 am |
it all depends on:
1- AC?
2-DC?
3-the RANGE ?( 1 ua is very different from 100A )
4- and if AC - the FREQUENCY range |
exodia505
Posted: Sun Mar 04, 2012 10:10 am |
i meant DC current (0-5A) _________________ NOway!! |
Posted: Sun Mar 04, 2012 10:27 am |
Hi side or low side sensing -or floating?
Whats the CIRCUIT you intend to use this with ??
Even with an optimum circuit,
keep in mind that with a 10 bit A/d pic
you can only resolve to 7.8 ma increments and 1.95 ma with a 12 bit PIC.
The circuit you will need depends on the answer you give to the first line of this message.
BTW: for real product - or school project?? |
gpsmikey
Posted: Sun Mar 04, 2012 10:35 am |
Contact or non-contact (can you insert a sense resistor in-line with the load or do you have to not modify the wiring) ? What kind of frequency response do you need ? (there is DC then there is "fluctuating DC" where you are monitoring a load for example). What kind of voltage drop can you tolerate across the sensor ? To "measure current" you first have to define the requirements of what sort of "intrusion" into the circuit you want to measure can be tolerated.
mikey _________________ mikey
SherpaDoug
Mike Walne
Where are you sensing? |
Posted: Tue Mar 06, 2012 3:37 am |
Is your current unipolar?
You said 0-5A, but could the current change direction? (i.e. -5A - 0 - +5A)
Where abouts in your circuit are you wanting to measure? (0V lead, above VDD, below VSS, floating)
Do you need a Hall effect probe?
And on and on .........
Mike |
