joseph20480
18f4550 : delay and timer0 problem... |
Posted: Mon Feb 27, 2012 3:44 pm |
I have a demoboard with a pic 18f4550 and 20Mhz crystal. I try to do a 10us interruption with a timer... but the delay isn't good.
My code is like that :
For beginning :
#include <18F4550.h>
#fuses NOWDT, HS, NOPROTECT, NOPUT
#use delay(clock=20M, crystal)
My interrupt function :
#int_timer0
void interruption_timer0()
output_high(pin_e1);
delay_us(1);
output_low(pin_e1);
set_timer0(0);
My void main(void) :
setup_timer_0(T0_INTERNAL|T0_DIV_1|T0_8_BIT);
set_timer0(0);
for(;;)
My result (with a scope) : the pulse on e1, 1.44us, interrupts every 63us...
I don't understand, because : (1/20M)*4*256=51.2us...
If someone have an idea...
Thanks in advance |
asmboy
Posted: Mon Feb 27, 2012 5:21 pm |
even if you COULD wish away the overhead of the ISR
- you will have precious little time to do any other processing of any use.
there are simply MUCH better, perfectly ACCURATE ways to make a repetitive pulse stream. I could do this with just a few - in fact damned few - 74HCT series IC's and a calculated master oscillator frequency.
who needs a PIC? what you are chasing is best done as a pure and really pretty simple bit of HARDWARE counters and gates alone.
OR a pretty dinky single chip
PLA - ( think GAL PAL FPGA etc etc )
let me share my favorite Larry Niven quote:
Quote: |
When all you have is a hammer, every problem needs to look like a nail.
Posted: Mon Feb 27, 2012 6:30 pm |
You could fix the problem by making the PIC run faster. The 18F4550
has a PLL and can run at 48 MHz with your crystal.
Change your first 3 lines to this:
#fuses HSPLL,NOWDT,NOPROTECT,NOLVP,USBDIV,PLL5,CPUDIV1
#use delay(clock=48M)
Then try your test again. |
