18f4550 : delay and timer0 problem...
joseph20480
PostPosted: Mon Feb 27, 2012 3:44 pm     Reply with quote
I have a demoboard with a pic 18f4550 and 20Mhz crystal. I try to do a 10us interruption with a timer... but the delay isn't good.
My code is like that :
For beginning :
#include <18F4550.h>
#fuses NOWDT, HS, NOPROTECT, NOPUT
#use delay(clock=20M, crystal)
My interrupt function :
#int_timer0
void interruption_timer0()
   output_high(pin_e1);
   delay_us(1);
   output_low(pin_e1);
   set_timer0(0);
My void main(void) :
   setup_timer_0(T0_INTERNAL|T0_DIV_1|T0_8_BIT);
    set_timer0(0);
   for(;;)
My result (with a scope) : the pulse on e1, 1.44us, interrupts every 63us...
I don't understand, because : (1/20M)*4*256=51.2us...
If someone have an idea...
Thanks in advance
PostPosted: Mon Feb 27, 2012 3:51 pm     Reply with quote
It takes time for the compiler to process the interrupt. This limits the
frequency at which interrupts can occur. Read these threads:
http://www.ccsinfo.com/forum/viewtopic.php?t=43399
http://www.ccsinfo.com/forum/viewtopic.php?t=29173
PostPosted: Mon Feb 27, 2012 5:21 pm     Reply with quote
even if you COULD wish away the overhead of the ISR
- you will have precious little time to do any other processing of any use.
there are simply MUCH better, perfectly ACCURATE ways to make a repetitive pulse stream. I could do this with just a few - in fact damned few - 74HCT series IC's and a calculated master oscillator frequency.
who needs a PIC? what you are chasing is best done as a pure and really pretty simple bit of HARDWARE counters and gates alone.
OR a pretty dinky single chip
PLA - ( think GAL PAL FPGA etc etc )
let me share my favorite Larry Niven quote:
When all you have is a hammer, every problem needs to look like a nail.
PostPosted: Mon Feb 27, 2012 6:30 pm     Reply with quote
You could fix the problem by making the PIC run faster. The 18F4550
has a PLL and can run at 48 MHz with your crystal.
Change your first 3 lines to this:
#fuses HSPLL,NOWDT,NOPROTECT,NOLVP,USBDIV,PLL5,CPUDIV1
#use delay(clock=48M)
Then try your test again.
