mauriciolacoste
mauriciolacoste
mauriciolacoste
PostPosted: Tue Feb 21, 2012 4:44 am     Reply with quote
I get the following error:
Duplicate #define Sad
This is the code:
// (C) copyright 2003 j.d.sandoz / jds-pic !at! losdos.dyndns.org
// released under the GNU GENERAL PUBLIC LICENSE (GPL)
// refer to http://www.gnu.org/licenses/gpl.txt
// This program is free software; you can redistribute it and/or modify
// it under the terms of the GNU General Public License as published by
// the Free Software Foundation; either version 2 of the License, or
// (at your option) any later version.
// This program is distributed in the hope that it will be useful,
// but WITHOUT ANY WARRANTY; without even the implied warranty of
// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
// GNU General Public License for more details.
// You should have received a copy of the GNU General Public License
// along with this program; if not, write to the Free Software
// Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
/***********************1Wire Class***********************/
/*Description: This class handles all communication */
/* between the processor and the 1wire */
/* sensors.
/*-------1-wire definitions-------*/
//#use delay(clock=4000000)
#define ONE_WIRE_PIN PIN_A2                              // here the error:  Duplicade #define
/*******************1-wire communication functions********************/
/************onewire_reset*************************************************/
/*This function initiates the 1wire bus */
/*PARAMETERS: */
/*RETURNS: */
void onewire_reset()  // OK if just using a single permanently connected device
 output_low( ONE_WIRE_PIN );
 delay_us( 500 ); // pull 1-wire low for reset pulse
 output_float( ONE_WIRE_PIN ); // float 1-wire high
 delay_us( 500 ); // wait-out remaining initialisation window.
 output_float(ONE_WIRE_PIN);
/*********************** onewire_write() ********************************/
/*This function writes a byte to the sensor.*/
/*Parameters: byte - the byte to be written to the 1-wire */
/*Returns: */
void onewire_write(int data)
 int count;
 for (count=0; count<8; ++count)
  output_low(ONE_WIRE_PIN);
  delay_us( 2 ); // pull 1-wire low to initiate write time-slot.
  output_bit(ONE_WIRE_PIN, shift_right(&data,1,0)); // set output bit on 1-wire
  delay_us( 60 ); // wait until end of write slot.
  output_float(ONE_WIRE_PIN); // set 1-wire high again,
  delay_us( 2 ); // for more than 1us minimum.
/*********************** read1wire() *********************************/
/*This function reads the 8 -bit data via the 1-wire sensor. */
/*Parameters: */
/*Returns: 8-bit (1-byte) data from sensor */
int onewire_read()
 int count, data;
  delay_us( 2 ); // pull 1-wire low to initiate read time-slot.
  output_float( ONE_WIRE_PIN ); // now let 1-wire float high,
  delay_us( 8 ); // let device state stabilise,
  shift_right(&data, 1 , input(ONE_WIRE_PIN)); // and load result.
  delay_us( 120 ); // wait until end of read slot.
 return( data );
Help????????
Thanks!!!!!
PostPosted: Tue Feb 21, 2012 7:14 am     Reply with quote
It means exactly what it says. Somewhere else in your program the same
line exists. You need to comment one of them out.
