mauriciolacoste
mauriciolacoste
mauriciolacoste
PostPosted: Tue Feb 21, 2012 4:44 am     Reply with quote
I get the following error:
Duplicate #define Sad
This is the code:
// (C) copyright 2003 j.d.sandoz / jds-pic !at! losdos.dyndns.org
// released under the GNU GENERAL PUBLIC LICENSE (GPL)
// refer to http://www.gnu.org/licenses/gpl.txt
// This program is free software; you can redistribute it and/or modify
// it under the terms of the GNU General Public License as published by
// the Free Software Foundation; either version 2 of the License, or
// (at your option) any later version.
// This program is distributed in the hope that it will be useful,
// but WITHOUT ANY WARRANTY; without even the implied warranty of
// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
// GNU General Public License for more details.
// You should have received a copy of the GNU General Public License
// along with this program; if not, write to the Free Software
// Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
/***********************1Wire Class***********************/
/*Description: This class handles all communication */
/* between the processor and the 1wire */
/* sensors.
/*-------1-wire definitions-------*/
//#use delay(clock=4000000)
#define ONE_WIRE_PIN PIN_A2                              // here the error:  Duplicade #define
/*******************1-wire communication functions********************/
/************onewire_reset*************************************************/
/*This function initiates the 1wire bus */
/*PARAMETERS: */
/*RETURNS: */
void onewire_reset()  // OK if just using a single permanently connected device
 output_low( ONE_WIRE_PIN );
 delay_us( 500 ); // pull 1-wire low for reset pulse
 output_float( ONE_WIRE_PIN ); // float 1-wire high
 delay_us( 500 ); // wait-out remaining initialisation window.
 output_float(ONE_WIRE_PIN);
/*********************** onewire_write() ********************************/
/*This function writes a byte to the sensor.*/
/*Parameters: byte - the byte to be written to the 1-wire */
/*Returns: */
void onewire_write(int data)
 int count;
 for (count=0; count<8; ++count)
  output_low(ONE_WIRE_PIN);
  delay_us( 2 ); // pull 1-wire low to initiate write time-slot.
  output_bit(ONE_WIRE_PIN, shift_right(&data,1,0)); // set output bit on 1-wire
  delay_us( 60 ); // wait until end of write slot.
  output_float(ONE_WIRE_PIN); // set 1-wire high again,
  delay_us( 2 ); // for more than 1us minimum.
/*********************** read1wire() *********************************/
/*This function reads the 8 -bit data via the 1-wire sensor. */
/*Parameters: */
/*Returns: 8-bit (1-byte) data from sensor */
int onewire_read()
 int count, data;
  delay_us( 2 ); // pull 1-wire low to initiate read time-slot.
  output_float( ONE_WIRE_PIN ); // now let 1-wire float high,
  delay_us( 8 ); // let device state stabilise,
  shift_right(&data, 1 , input(ONE_WIRE_PIN)); // and load result.
  delay_us( 120 ); // wait until end of read slot.
 return( data );
Help????????
Thanks!!!!!
dyeatman
PostPosted: Tue Feb 21, 2012 7:14 am     Reply with quote
It means exactly what it says. Somewhere else in your program the same
line exists. You need to comment one of them out.
Google and Forum Search are some of your best tools
