18f86j50 USB problem
chaowan_jun
PostPosted: Fri Jan 20, 2012 1:58 pm     Reply with quote
it's show "usb not recognize"
HID Mouse --- the cursor must to move in a circle form
This is my code that work on PIC18F4550 But when I change a controller to PIC18F86J50 it doesn't work
my ccs version 4.114
my xtal is 20 MHz
help me plzzz
thank you very much
#include <18F86j50.h>
#fuses HSPLL,PLL5,NOWDT,NOPROTECT,NOCPUDIV
#use delay(clock=48000000)
#include <pic18_usb.h>
#include <usb_desc_mouse.h>
#include <USB.c>
#byte OSCTUNE = 0xF9B
#bit PLLEN = OSCTUNE.6
void main(void) {
   PLLEN = 1;
   delay_ms(10);
  #define MOUSE_SEQUENCE_STEPS  16
   const char mouse_seq[MOUSE_SEQUENCE_STEPS]=
      {0, 1, 3, 4, 4, 4, 3, 1, 0, -1, -3, -4, -4, -4, -3, -1};
   int8 out_data[4];
   unsigned int8 x_seq=0; unsigned int8 y_seq=MOUSE_SEQUENCE_STEPS/4;
   unsigned int8 count=0;
   usb_init_cs();
   while (TRUE) {
      usb_task();
      if (usb_enumerated()) {
         out_data[0]=0; //button state goes here
         out_data[1]=mouse_seq[x_seq];
         out_data[2]=mouse_seq[y_seq];
         out_data[3]=0; //wheel state goes here
         if (usb_put_packet(1,out_data,4,USB_DTS_TOGGLE))
            count++;
         if (count > 10) {
            if (++x_seq>=MOUSE_SEQUENCE_STEPS) {x_seq=0;}
            if (++y_seq>=MOUSE_SEQUENCE_STEPS) {y_seq=0;}
            count=0;
         delay_ms(10);
chaowan_jun
PostPosted: Mon Jan 30, 2012 7:06 am     Reply with quote
Help me please !!!!
PostPosted: Mon Jan 30, 2012 7:16 am     Reply with quote
Get both datasheets and compare what is different about the two devices.
Have you got the 'Hello World' and 'blinking LED' programs to run on the 2nd device ?
As for the message, if that's from a PC running Windows, odds are you didn't load whatever driver is necessary for the OS to recognize the 'new' USB device( the PIC).
