sahu77
scroll Text on 16*2 lcd |
Posted: Fri Jan 27, 2012 10:16 am |
How can I use scroll Text on 16*2 lcd. I use flex_lcd.c ? _________________ sahu |
ezflyr
Posted: Fri Jan 27, 2012 11:32 am |
Here is a code snippet that illustrates scrolling on an LCD:
char message[15] = "Hello World! ";
int8 ctr;
for (ctr=0;ctr<14;ctr++) {
lcd_gotoxy(1,2);
printf(lcd_putc,"%s",message+ctr);
John |
sahu77
Posted: Fri Jan 27, 2012 12:14 pm |
ezflyr wrote: | Hi,
int8 ctr;
lcd_gotoxy(1,2);
John |
its work as
Code: | Hello World!
ello World!
llo World!
lo World!
o World!
World!
World!
orld!
orld!
rld!
ld!
d!
i want as
d!
ld!
rld!
orld!
Hello World!
hope understand what i want to say u ?
sorry for my bad English . _________________ sahu |
Joined: 01 Jul 2010 Posts: 9177 Location: Greensville,Ontario
Posted: Fri Jan 27, 2012 1:57 pm |
Well you didn't specify which direction !!
We had no example to see what you really wnated.
Simply redo the counter and starting position of the message.
Use graph paper to layout what you want,decide on whether the counter should count up or down, and where 'start' location will be.
10 lines of code..... |
sahu77
Posted: Sat Jan 28, 2012 10:37 am |
Thank you very much PCM!! It works perfect! but has 1 problem. as i use
Code: | lcd_gotoxy(1,1);
printf(lcd_putc,"%s",message_1);
lcd_scroll_right();
lcd_gotoxy(1,2);
printf ( lcd_putc, "message_2" );
delay_ms(500); |
my aim is only message_1 scroll_right .as i use message_1 & message_2 both are scroll_right . _________________ sahu |
Posted: Sat Jan 28, 2012 11:05 am |
So, you have to use the software approach as ezflyr has already shown, just with the direction reversed (temtronic's post). The hardware scrolling only works for the whole screen.
