scroll Text on 16*2 lcd
sahu77
PostPosted: Fri Jan 27, 2012 10:16 am     Reply with quote
How can I use scroll Text on 16*2 lcd. I use flex_lcd.c ?
sahu
ezflyr
PostPosted: Fri Jan 27, 2012 11:32 am     Reply with quote
Here is a code snippet that illustrates scrolling on an LCD:
char message[15] = "Hello World!  ";
   int8 ctr;
   for (ctr=0;ctr<14;ctr++) {
       lcd_gotoxy(1,2);
       printf(lcd_putc,"%s",message+ctr);
John
sahu77
PostPosted: Fri Jan 27, 2012 12:14 pm     Reply with quote
ezflyr wrote:
   int8 ctr;
       lcd_gotoxy(1,2);
John
its work as
Hello World!
ello World!
llo World!
lo World!
o World!
 World!
World!
orld!
orld!
rld!
ld!
d!
i want as
d!
ld!
rld!
orld!
Hello World!
hope understand what i want to say u ?
sorry for my bad English .
sahu
PostPosted: Fri Jan 27, 2012 1:57 pm     Reply with quote
Well you didn't specify which direction !!
We had no example to see what you really wnated.
Simply redo the counter and starting position of the message.
Use graph paper to layout what you want,decide on whether the counter should count up or down, and where 'start' location will be.
10 lines of code.....
PostPosted: Fri Jan 27, 2012 2:06 pm     Reply with quote
The method shown above is software side scrolling.
The thread below has code to use the LCD's hardware to do side scrolling.
http://www.ccsinfo.com/forum/viewtopic.php?t=42792
sahu77
PostPosted: Sat Jan 28, 2012 10:37 am     Reply with quote
Thank you very much PCM!! It works perfect! but has 1 problem. as i use
        lcd_gotoxy(1,1);
        printf(lcd_putc,"%s",message_1);
 lcd_scroll_right();
           lcd_gotoxy(1,2);
            printf ( lcd_putc, "message_2" );
my aim is only message_1 scroll_right .as i use message_1 & message_2 both are scroll_right .
sahu
PostPosted: Sat Jan 28, 2012 11:05 am     Reply with quote
So, you have to use the software approach as ezflyr has already shown, just with the direction reversed (temtronic's post). The hardware scrolling only works for the whole screen.
