Use timer interrupts to start transmitting interrupts
cchappyboy
PostPosted: Tue Jan 10, 2012 4:05 pm     Reply with quote
Is that possible to start a transmitting interrupts in a timer interrupt for sending out data once in certain time period.
#int_timer1
void time1_isr()
set_timer1(0xbf5);
enable_interrupts(int_tbe);
#int_tbe
void serial_isr() {
output_high(pin_a2);
if(t_next_in!=t_next_out)
      putc(t_buffer[t_next_out]);
      t_next_out=(t_next_out+1) % T_BUFFER_SIZE;
   disable_interrupts(int_tbe);
Thanks in advance for any help.
asmboy
PostPosted: Tue Jan 10, 2012 5:05 pm     Reply with quote
ANSWER:
yes it should be possible
but ONE of your problems is it keep repeating in the timer isr
STATIC int1 TX_armed=0; // set this to '1' elsewhere in your program when you
//have data you want to release on timer INT - this will enable it only
// ONCE and the send routine DISARMS the control flag when TX empty
// routine is done
#int_timer1
void time1_isr() {
    set_timer1(0xbf5);
    if (TX_ARMED){
        TX_ARMED=0;
#int_tbe
void serial_isr() {
   output_high(pin_a2); // whatever
   if(t_next_in!=t_next_out)   {
       t_next_out++;
       if(t_next_out==T_BUFFER_SIZE)  t_next_out=0;
    else{
    tx_armed=0;
i also cleaned up an inefficiency in the modulus % usage in the circular buffer.
