Posted: Tue Jan 10, 2012 5:05 pm
ANSWER:
yes it should be possible
but ONE of your problems is it keep repeating in the timer isr
STATIC int1 TX_armed=0; // set this to '1' elsewhere in your program when you
//have data you want to release on timer INT - this will enable it only
// ONCE and the send routine DISARMS the control flag when TX empty
// routine is done
