joseph20480
ex_mmcsd : Init ok with or without card... |
Posted: Thu Dec 22, 2011 3:01 pm |
Hi !
I try to connect a sdcard/mmc to a pic (pic18f4550 / CCS 4.114). For that I want use the ex.mmcsd... but I have somethings not expected.
When I call the function mmcsd_init(), she return alway ok... with or without memory card.
It's a another of ccs or I have forgotten something ?
Thanks in advance.
joseph |
Joined: 01 Jul 2010 Posts: 9225 Location: Greensville,Ontario
Posted: Thu Dec 22, 2011 3:26 pm |
Please provide us a schematic diagram of your system.
As well as your 'main' program. |
asmallri
Re: ex_mmcsd : Init ok with or without card... |
Posted: Thu Dec 22, 2011 5:24 pm |
joseph20480 wrote: | Hi !
Thanks in advance.
joseph |
I cannot speak specifically to the CCS implementation however it maybe that any response other than 0xff from the card is considered to be successful. If you do not have a pull-up resistor on DO of the SD/MMC card socket then without a card the input to the PIC is floating as a consequence the PIC may, and often will, read a non 0xff value. _________________ Regards, Andrew
joseph20480
Posted: Fri Dec 23, 2011 2:38 am |
Thanks for your reply,
I will seen my schematic and post more informations....
About your reflexion, that is the sd card not responding seem to be Ok....i'm not sure... |
