I had a similar problem, ending up reinstalling mplab and ccs to no avail. I contacted ccs - the solution is to check and ensure that you have all the .crg files in the same folder as the ccsc.exe.
In my case, the pch.crg file is already in the same folder as ccsc.exe, so something else must be wrong.
Thanks.
Posted: Tue Dec 20, 2011 8:30 pm
The tool location setting is exactly where it is: C:\Program Files\PICCcommandLine\Ccsc.exe
Try to install CCS in the default directory, which is:
