MPLAB Plugin integration problem
johnl
PostPosted: Tue Dec 20, 2011 7:35 pm     Reply with quote
MPLAB v8.83 with the latest PCH command line version. Win XP home.
Compiler works from a DOS prompt window and the tool location setting is exactly where it is: C:\Program Files\PICCcommandLine\Ccsc.exe
When I run Make (F10), the "CCS error" window that begins with "The CCS Compiler is not installed on this computer...." pops up.
PostPosted: Tue Dec 20, 2011 7:58 pm     Reply with quote
See this previous thread on the topic:
http://www.ccsinfo.com/forum/viewtopic.php?p=5778
johnl
PostPosted: Tue Dec 20, 2011 8:13 pm     Reply with quote
From that 2003 thread, I got this:
I had a similar problem, ending up reinstalling mplab and ccs to no avail. I contacted ccs - the solution is to check and ensure that you have all the .crg files in the same folder as the ccsc.exe.
In my case, the pch.crg file is already in the same folder as ccsc.exe, so something else must be wrong.
Thanks.
PostPosted: Tue Dec 20, 2011 8:30 pm     Reply with quote
The tool location setting is exactly where it is: C:\Program Files\PICCcommandLine\Ccsc.exe
Try to install CCS in the default directory, which is:
c:\Program Files\PICC\
Do everything according to the default method:
http://www.ccsinfo.com/faq.php?page=ccs_mplab
