PIC16877A CCS how to make the program will only printf 1?
sfchew7
PostPosted: Fri Nov 11, 2011 8:44 pm     Reply with quote
PIC16877A CCS how to make the program will only printf 1 time?
I wish to make the code below will only execute "printf" one time. How should I edit the code below ?
thanks
if((input(pin_a0)==1) && (input(pin_a1)==1) && (input(pin_a2)==1))
lcd_putc("\fPL available:0");
printf("\fPL available:0");
else if((input(pin_a0)==0) && (input(pin_a1)==0) && (input(pin_a2)==0))
lcd_putc("\fPL available:3");
delay_ms(2000);
lcd_putc("\fPL1-empty");
lcd_putc("\nPL2-empty");
lcd_putc("\fPL3-empty");
printf("\fPL available:3");
PostPosted: Sat Nov 12, 2011 3:09 am     Reply with quote
Something like:
//Learn to indent - makes code easier to follow....
int1 done=FALSE; //with your variable declarations
do {
    if((input(pin_a0)==1) && (input(pin_a1)==1) && (input(pin_a2)==1)) {
       done=TRUE;
     else if((input(pin_a0)==0) && (input(pin_a1)==0) &&  \
     (input(pin_a2)==0)) {
       delay_ms(2000);
       done=TRUE;
} while (!done);
So the loop exits, when 'done' goes TRUE.
If this is the main, the chip will drop through to a hidden 'sleep' after the code, and stop running. Otherwise add whatever else you want to happen here.
