PIC16877A CCS how to make the program will only printf 1?
Posted: Fri Nov 11, 2011 8:44 pm
PIC16877A CCS how to make the program will only printf 1 time?
I wish to make the code below will only execute "printf" one time. How should I edit the code below ?
thanks
printf("\fPL available:3");
done=TRUE;
} while (!done);
So the loop exits, when 'done' goes TRUE.
If this is the main, the chip will drop through to a hidden 'sleep' after the code, and stop running. Otherwise add whatever else you want to happen here.
