Library MCP4728 D/A I2C converter
oiluj
PostPosted: Mon Nov 07, 2011 5:08 pm     Reply with quote
I'm a student of Electrical Engineering in UFSJ, Brazil.
And I need write a program for communicates PIC18F4550 with MCP4728 D/A converter,
but I didn't find libraries for the converter.
I'd like if possible that someone posted the library for me.
Thanks all.
n-squared
PostPosted: Sat Nov 12, 2011 3:33 pm     Reply with quote
Hi
I use the MCP4728 with the following code.
#define AOUT_BUSY PIN_A3 // change to reflect YOUR hardware
#define AOUT_SDA  PIN_F2
#define AOUT_SCL  PIN_F1
#use I2C(master, scl=AOUT_SCL, sda=AOUT_SDA, fast,stream=AOUT)
void set_analog_output(int8 channel, int16 value)
  int1 ack;
  i2c_start(AOUT);
  ack = i2c_write(AOUT, 0xC0);
  ack = i2c_write(AOUT, 0x58 + (channel << 1));
  ack = i2c_write(AOUT, make8(value,1));
  ack = i2c_write(AOUT, make8(value,0));
  i2c_stop(AOUT);
BR
NN
Every solution has a problem.
oiluj
PostPosted: Sun Nov 13, 2011 4:51 pm     Reply with quote
I wrote this code for comunicate with MCP4728:
void mcp4728_set_voltage(int speedA,int speedB, int speedC, int speedD )
  conversion(speedA, speedB, speedC, speedD);
  i2c_start();
  i2c_write(0xC0);            // I2C write address
  i2c_write(0x50);            //Modo de Escrita e Canal de Inicio
  i2c_write(dadoA);
  i2c_write(tensaolsbA);
  i2c_write(dadoB);
  i2c_write(tensaolsbB);
  i2c_write(dadoC);
  i2c_write(tensaolsbC);
  i2c_write(dadoD);
  i2c_write(tensaolsbD);
  i2c_stop();
Do you think this code is correct??
Thanks!
