oiluj
Library MCP4728 D/A I2C converter |
Posted: Mon Nov 07, 2011 5:08 pm |
I'm a student of Electrical Engineering in UFSJ, Brazil.
And I need write a program for communicates PIC18F4550 with MCP4728 D/A converter,
but I didn't find libraries for the converter.
I'd like if possible that someone posted the library for me.
Thanks all. |
n-squared
Posted: Sat Nov 12, 2011 3:33 pm |
Hi
I use the MCP4728 with the following code.
#define AOUT_BUSY PIN_A3 // change to reflect YOUR hardware
#define AOUT_SDA PIN_F2
#define AOUT_SCL PIN_F1
#use I2C(master, scl=AOUT_SCL, sda=AOUT_SDA, fast,stream=AOUT)
void set_analog_output(int8 channel, int16 value)
int1 ack;
i2c_start(AOUT);
ack = i2c_write(AOUT, 0xC0);
ack = i2c_write(AOUT, 0x58 + (channel << 1));
ack = i2c_write(AOUT, make8(value,1));
ack = i2c_write(AOUT, make8(value,0));
i2c_stop(AOUT);
BR
NN _________________ Every solution has a problem. |
oiluj
Posted: Sun Nov 13, 2011 4:51 pm |
I wrote this code for comunicate with MCP4728:
Code: | void mcp4728_set_voltage(int speedA,int speedB, int speedC, int speedD )
conversion(speedA, speedB, speedC, speedD);
i2c_start();
i2c_write(0xC0); // I2C write address
i2c_write(0x50); //Modo de Escrita e Canal de Inicio
i2c_write(dadoA);
i2c_write(tensaolsbA);
i2c_write(dadoB);
i2c_write(tensaolsbB);
i2c_write(dadoC);
i2c_write(tensaolsbC);
i2c_write(dadoD);
i2c_write(tensaolsbD);
i2c_stop();
Do you think this code is correct??
Thanks! |
