PWM Question
MexiCub125
PWM Question
PostPosted: Wed Nov 09, 2011 9:31 pm     Reply with quote
I am using a PIC16F887 for PWM to a Standard Servo. I wanted to know with a clock of 20Mhz, if you can output a 50HZ output to the motors PWM input? The 50HZ is the needed input from the PIC.
thanks
PostPosted: Wed Nov 09, 2011 11:10 pm     Reply with quote
to the motors PWM input.
This post has a link to a PWM frequency formula which will answer your
question. It also has other PWM links:
http://www.ccsinfo.com/forum/viewtopic.php?t=45968&start=1
This thread discusses low speed PWM:
http://www.ccsinfo.com/forum/viewtopic.php?t=37807
