I am using a PIC16F887 for PWM to a Standard Servo. I wanted to know with a clock of 20Mhz, if you can output a 50HZ output to the motors PWM input? The 50HZ is the needed input from the PIC.
thanks
Posted: Wed Nov 09, 2011 11:10 pm
to the motors PWM input.
