krigisk
18F452 How to disable Int of RB1 |
Posted: Thu Nov 10, 2011 11:22 am |
Hi guys. It's my first post and I have a problem.
I need to disable the interrupt function of the RB1 and RB2 of the 18F452. I have a keypad connected in the portB and I cannot change for many reasons.
I was using 16f877a, but my code it's too large for the memory, so I decide to change to the 18F family.
Can anyone help me?
Thank you guys
#include <18f452.h> // identifica microcontrolador alvo
#fuses XT,NOWDT,NOPROTECT,PUT,NOLVP
#use delay (clock=4000000) // <- define cristal para 4Mhz. Para outros valores, mude e recompile.
#include <flexstdio.h>
#int_RB
void trata_emerg(void)
lcd_init();
lcd_putc("\fInterrupcao");
clear_interrupt(INT_RB);
void main() // função principal
int16 senha_mestre=1234;
int16 senha_dig,senha_dig2,senha_unlock;
int16 valor1,valor2,select,errada;
enable_interrupts(INT_RB);
output_a(0x00); // desliga todo PORTA
output_b(0x00); // desliga todo PORTB
output_c(0x00); // desliga todo PORTC
output_d(0x00); // desliga todo PORTD
lcd_init();
lcd_putc("\fBem vindo!");
while(true)
lcd_putc("\fSelecione uma\nopcao a seguir");
opcoes:
lcd_putc("\f1.Liberar acesso\n2.Criar usuario");
lcd_putc("\f3.Soar alarme\n4.Bloquear tudo");
lcd_putc("\fOpcao:\n=>");
select=cusco_readkbd(0);
switch(select)
case 1:
goto acesso;
case 2:
goto cadastro;
case 3:
goto alarme;
case 4:
goto bloqueio;
default:
lcd_putc("\fOpcao invalida");
goto opcoes;
acesso:
lcd_putc("\fPara acessar\ndigite a senha");
lcd_putc("\fSenha de usuario\n=>");
senha_dig=cusco_readkbd(0);
if(senha_dig==valor1){
lcd_putc("\fAcesso liberado!");
output_high(PIN_A0);
delay_ms(50);
output_low(PIN_A0);
delay_ms(50);
delay_ms(50);
output_low(PIN_A0);
delay_ms(50);
output_low(PIN_A0);
delay_ms(50);
output_low(PIN_A0);
goto opcoes;
else{
errada++;
if(errada==3){
lcd_putc("\f3 tentativas sem\nsucesso!");
lcd_putc("\fAtivar bloqueio:\n=>bloqueado");
goto bloqueio;
else{
lcd_putc("\fSenha errada\nTente novamente");
goto acesso;
cadastro:
lcd_putc("\fSenha mestre\n=>");
senha_dig2=cusco_readkbd(0);
if(senha_dig2==senha_mestre){
else{
lcd_putc("\fSenha errada");
goto cadastro;
lcd_putc("\fDefinicao de\nsenha de usuario");
lcd_putc("\fSenha desejada\n=>");
valor1=cusco_readkbd(0);
lcd_putc("\fDigite novamente\n=>");
valor2=cusco_readkbd(0);
if(valor1==valor2){
lcd_putc("\fSenha definida!");
//write_eeprom(0x00, 0x50);
goto opcoes;
else{
lcd_putc("\fVoce digitou\nalgo errado");
goto cadastro;
alarme:
lcd_putc("\fAlarme");
delay_ms(2);
goto opcoes;
bloqueio:
lcd_putc("\fSistema \nbloqueado");
lcd_putc("\fSenha mestre:\n=>");
senha_unlock=cusco_readkbd(0);
if(senha_unlock==senha_mestre){
lcd_putc("\fSistema liberado");
output_low(PIN_A0);
goto opcoes;
else{
goto bloqueio;
Posted: Thu Nov 10, 2011 1:13 pm |
I need to disable the interrupt function of the RB1 and RB2 of the 18F452. |
18F452 doesn't have #int_rb interrupts on pins B1 and B2. It only has
them on pins B4-B7. The 18F452 data sheet says:
Quote: |
8.8 PORTB Interrupt-on-Change
An input change on PORTB<7:4> sets flag bit RBIF
(INTCON<0>). The interrupt can be enabled/disabled
by setting/clearing enable bit, RBIE (INTCON<3>).
Interrupt priority for PORTB interrupt-on-change is
determined by the value contained in the interrupt
priority bit, RBIP (INTCON2<0>).
Link to data sheet:
http://ww1.microchip.com/downloads/en/DeviceDoc/39564c.pdf |
krigisk
Posted: Thu Nov 10, 2011 2:40 pm |
PCM PROGRAMMER thanks for your aswer.
I change my keypad position to the portC, works fine.
Now I need to activate a emergency button in the portB.
Do you know a better way to do that? Cause I try the #INT_BUTTON and doesn't works :/
Thank you |
Posted: Thu Nov 10, 2011 2:54 pm |
This thread discusses using #int_ext on pin B0:
http://www.ccsinfo.com/forum/viewtopic.php?t=45315
You need to connect a push-button switch to pin B0 as shown below.
Instead of using an external resistor shown below, you could enable
PortB pull-ups by using the port_b_pullups() function.
+5v
> 4.7K
< ___ Switch
To | _|_|_
PIC -----------------o o------
pin RB0 |
--- GND
