18F452 How to disable Int of RB1
krigisk
PostPosted: Thu Nov 10, 2011 11:22 am     Reply with quote
Hi guys. It's my first post and I have a problem.
I need to disable the interrupt function of the RB1 and RB2 of the 18F452. I have a keypad connected in the portB and I cannot change for many reasons.
I was using 16f877a, but my code it's too large for the memory, so I decide to change to the 18F family.
Can anyone help me?
Thank you guys
#include <18f452.h>         // identifica microcontrolador alvo
#fuses XT,NOWDT,NOPROTECT,PUT,NOLVP
#use delay (clock=4000000)  // <- define cristal para 4Mhz. Para outros valores, mude e recompile.
#include <flexstdio.h>
#int_RB
void trata_emerg(void)
   lcd_init();
   lcd_putc("\fInterrupcao");
   clear_interrupt(INT_RB);
void main()       // função principal
  int16 senha_mestre=1234;
  int16 senha_dig,senha_dig2,senha_unlock;
  int16 valor1,valor2,select,errada;
  enable_interrupts(INT_RB);
  output_a(0x00);  // desliga todo PORTA
  output_b(0x00);  // desliga todo PORTB
  output_c(0x00);  // desliga todo PORTC
  output_d(0x00);  // desliga todo PORTD
  lcd_init();
  lcd_putc("\fBem vindo!");
     while(true)
         lcd_putc("\fSelecione uma\nopcao a seguir");
         opcoes:
            lcd_putc("\f1.Liberar acesso\n2.Criar usuario");
            lcd_putc("\f3.Soar alarme\n4.Bloquear tudo");
            lcd_putc("\fOpcao:\n=>");
            select=cusco_readkbd(0);
               switch(select)
                  case 1:
                  goto acesso;
                  case 2:
                  goto cadastro;
                  case 3:
                  goto alarme;
                  case 4:
                  goto bloqueio;
                  default:
                  lcd_putc("\fOpcao invalida");
                  goto opcoes;
acesso:
   lcd_putc("\fPara acessar\ndigite a senha");
   lcd_putc("\fSenha de usuario\n=>");
   senha_dig=cusco_readkbd(0);
      if(senha_dig==valor1){
         lcd_putc("\fAcesso liberado!");
         output_high(PIN_A0);
         delay_ms(50);
         output_low(PIN_A0);
         delay_ms(50);
         delay_ms(50);
         output_low(PIN_A0);
         delay_ms(50);
         output_low(PIN_A0);
         delay_ms(50);
         output_low(PIN_A0);
         goto opcoes;
      else{
         errada++;
            if(errada==3){
               lcd_putc("\f3 tentativas sem\nsucesso!");
               lcd_putc("\fAtivar bloqueio:\n=>bloqueado");
               goto bloqueio;
            else{
               lcd_putc("\fSenha errada\nTente novamente");
               goto acesso;
cadastro:
   lcd_putc("\fSenha mestre\n=>");
   senha_dig2=cusco_readkbd(0);
      if(senha_dig2==senha_mestre){
      else{
         lcd_putc("\fSenha errada");
         goto cadastro;
   lcd_putc("\fDefinicao de\nsenha de usuario");
   lcd_putc("\fSenha desejada\n=>");
   valor1=cusco_readkbd(0);
   lcd_putc("\fDigite novamente\n=>");
   valor2=cusco_readkbd(0);
      if(valor1==valor2){
         lcd_putc("\fSenha definida!");
         //write_eeprom(0x00, 0x50);
         goto opcoes;
      else{
         lcd_putc("\fVoce digitou\nalgo errado");
         goto cadastro;
alarme:
   lcd_putc("\fAlarme");
   delay_ms(2);
   goto opcoes;
         bloqueio:
            lcd_putc("\fSistema \nbloqueado");
            lcd_putc("\fSenha mestre:\n=>");
            senha_unlock=cusco_readkbd(0);
               if(senha_unlock==senha_mestre){
                  lcd_putc("\fSistema liberado");
                  output_low(PIN_A0);
                  goto opcoes;
               else{
                  goto bloqueio;
PostPosted: Thu Nov 10, 2011 1:13 pm     Reply with quote
18F452 doesn't have #int_rb interrupts on pins B1 and B2. It only has
them on pins B4-B7. The 18F452 data sheet says:
8.8 PORTB Interrupt-on-Change
An input change on PORTB<7:4> sets flag bit RBIF
(INTCON<0>). The interrupt can be enabled/disabled
by setting/clearing enable bit, RBIE (INTCON<3>).
Interrupt priority for PORTB interrupt-on-change is
determined by the value contained in the interrupt
priority bit, RBIP (INTCON2<0>).
Link to data sheet:
http://ww1.microchip.com/downloads/en/DeviceDoc/39564c.pdf
krigisk
PostPosted: Thu Nov 10, 2011 2:40 pm     Reply with quote
PCM PROGRAMMER thanks for your aswer.
I change my keypad position to the portC, works fine.
Now I need to activate a emergency button in the portB.
Do you know a better way to do that? Cause I try the #INT_BUTTON and doesn't works :/
Thank you
PostPosted: Thu Nov 10, 2011 2:54 pm     Reply with quote
This thread discusses using #int_ext on pin B0:
http://www.ccsinfo.com/forum/viewtopic.php?t=45315
You need to connect a push-button switch to pin B0 as shown below.
Instead of using an external resistor shown below, you could enable
PortB pull-ups by using the port_b_pullups() function.
           +5v
            > 4.7K
            <         ___  Switch
To          |        _|_|_
PIC -----------------o   o------
pin RB0                        |
                              --- GND
