Jum
Problem sending ALT+B in ex_usb_kbmouse2 example code. |
Posted: Sun Oct 23, 2011 12:01 pm |
I have a problem using the PIC18F2550 emulating a mouse and keyboard using USB HID.
I'm using the 4.106 version of ccs and example ex_usb_kbmouse2.
My problem is I'm not able to send special key combinations (alt, control, shift).
If I try to send Alt + B does not work.
The code is:
if (BUTTON_PRESSED()) {
tx_msg[8]={2,0,0,0,0,0,0,0};
tx_msg[1] = 4; //send press Alt?
usb_put_packet(1,tx_msg,sizeof(tx_msg),USB_DTS_TOGGLE);
delay_ms(50);
tx_msg[3] = 5 // Send press B.
delay_ms(50);
tx_msg[3] = 0 // send no key press.
delay_ms(50);
tx_msg[1] = 4; //send no Alt press
delay_ms(50);
The rest of the code is the example ex_usb_kbmouse2.
What is the correct way to send Alt +1?
Some sample code?
Thanks and sorry for my bad English. |
