Problem sending ALT+B in ex_usb_kbmouse2 example code.
Jum
PostPosted: Sun Oct 23, 2011 12:01 pm     Reply with quote
I have a problem using the PIC18F2550 emulating a mouse and keyboard using USB HID.
I'm using the 4.106 version of ccs and example ex_usb_kbmouse2.
My problem is I'm not able to send special key combinations (alt, control, shift).
If I try to send Alt + B does not work.
The code is:
if (BUTTON_PRESSED())    {
     tx_msg[8]={2,0,0,0,0,0,0,0};
      tx_msg[1] = 4; //send press Alt?
   usb_put_packet(1,tx_msg,sizeof(tx_msg),USB_DTS_TOGGLE);
                delay_ms(50);
   tx_msg[3] = 5 // Send press B.
          delay_ms(50);
   tx_msg[3] = 0 // send no key press.
          delay_ms(50);
   tx_msg[1] = 4; //send no Alt press
        delay_ms(50);
The rest of the code is the example ex_usb_kbmouse2.
What is the correct way to send Alt +1?
Some sample code?
Thanks and sorry for my bad English.
fkl
re
PostPosted: Sun Oct 23, 2011 12:38 pm     Reply with quote
Hello.
I too am trying to find out 'emulating keyboard"
Can you put the code of the program?
ps
sorry for my english
Jum
PostPosted: Sun Oct 23, 2011 4:08 pm     Reply with quote
The code is in examples ccs. The code is called ex_usb_kbmouse2
