v4.124 interrupts errors
open_my
PostPosted: Fri Sep 23, 2011 9:08 am     Reply with quote
yes, i use code
#include <16F887.h>
#INT_RB
void rb_isr()
output_toggle (PIN_D2) ;
   IF (input (PIN_B0) )
      output_toggle (PIN_D0) ;
   enable_interrupts(INT_RB);// turn on interrupts
   WHILE (TRUE)
      output_toggle (PIN_D1);
      delay_ms (100) ;
is work, but
#include <16F887.h>
#INT_RB
void rb_isr()
//!   IF (input (PIN_B0) )
//!      output_toggle (PIN_D0) ;
   WHILE (TRUE)
      delay_ms (100) ;
interrupts loop, never return to main.
What is this error ? code or compilers ?
please help.
PostPosted: Fri Sep 23, 2011 9:43 am     Reply with quote
Read the datasheet. You have to read port B once to reset the input mismatch condition, otherwise, the interupt will be executed permanently.
input(PIN_B0) does it.
open_my
PostPosted: Fri Sep 23, 2011 9:58 am     Reply with quote
thank.
forget datasheet, this stupid Embarassed
