open_my
v4.124 interrupts errors |
Posted: Fri Sep 23, 2011 9:08 am |
yes, i use code
Code: | #include <16F887.h>
#INT_RB
void rb_isr()
output_toggle (PIN_D2) ;
IF (input (PIN_B0) )
output_toggle (PIN_D0) ;
enable_interrupts(INT_RB);// turn on interrupts
WHILE (TRUE)
output_toggle (PIN_D1);
delay_ms (100) ;
is work, but
#INT_RB
void rb_isr()
//! IF (input (PIN_B0) )
//! output_toggle (PIN_D0) ;
WHILE (TRUE)
delay_ms (100) ;
interrupts loop, never return to main.
What is this error ? code or compilers ?
please help. |
Posted: Fri Sep 23, 2011 9:43 am |
Read the datasheet. You have to read port B once to reset the input mismatch condition, otherwise, the interupt will be executed permanently.
input(PIN_B0) does it. |
open_my
Posted: Fri Sep 23, 2011 9:58 am |
FvM wrote: | Read the datasheet. You have to read port B once to reset the input mismatch condition, otherwise, the interupt will be executed permanently.
thank.
forget datasheet, this stupid ![Embarassed](images/smiles/icon_redface.gif) |
