mehmetem
pic16f877a i2c slave problem |
Posted: Fri Jul 29, 2011 8:25 am |
Hi All,
I have a problem; I could not simulate ex_slave example.
My master code:
#include <16F877A.h>
#device adc=8
#FUSES PROTECT //Code protected from reads
#use i2c(Master,Slow,sda=PIN_C4,scl=PIN_C3,force_hw)#include <2402.C>
byte gelen=0;
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
init_ext_eeprom();
// TODO: USER CODE!!
gelen= read_ext_eeprom(0x03);
My slave code is
#if defined(__PCM__)
#include <16F877.h>
#elif defined(__PCH__)
#include <18F452.h>
#endif
#use i2c(SLAVE, SDA=PIN_C4, SCL=PIN_C3, address=0xa0)
BYTE address, buffer[0x10];
#INT_SSP
void ssp_interupt ()
BYTE incoming, state;
state = i2c_isr_state();
if(state <= 0x80) //Master is sending data
incoming = i2c_read();
if(state == 1) //First received byte is address
address = incoming;
if(state == 2) //Second received byte is data
buffer[address] = incoming;
if(state == 0x80) //Master is requesting data
i2c_write(buffer[address]);
void main ()
int i=0;
enable_interrupts(INT_SSP);
for (i=0;i<16;i++)
{buffer[i]=0x37;}
while (TRUE) {}
and my problem: Received data all times 80. Where is my mistake? I could not find. Here is a Proteus picture:
I am sorry for my broken English. _________________ trainee |
Posted: Fri Jul 29, 2011 8:51 am |
Probably a Proteus problem as it is full of bugs, errors, glitches etc.
You should use real hardware.
If you can't contact a Proteus help forum or the mfr of the simulator.
There are working code examples in the CCS examples folder you might consult, see if they work under Proteus. |
mehmetem
Thank you, I solved problem. |
Posted: Wed Aug 03, 2011 12:57 am |
![Smile](images/smiles/icon_smile.gif) _________________ trainee |
PEDE
Posted: Sat Sep 10, 2011 10:29 am |
How did you fix your problem? Thx... |
mehmetem
There is not anything, Don't forget pull-up' MY WORKING CODE |
Posted: Sat Sep 10, 2011 2:12 pm |
BYTE address, BufferTxt[20], buffer[20];
#INT_SSP
address = incoming;
AND MASTER
Code: | while(1)
init_ext_eeprom();
PresetNumber= read_ext_eeprom(0x09);
if (PresetNumber!=PresetNumberOld)
CalcPhase();
yerptr=&(Rpm);
countL=*(yerPtr);
write_ext_eeprom(0x07,CountL);
countH=*(yerPtr+1);
write_ext_eeprom(0x08,CountH);
delay_ms(40);
