pic16f877a i2c slave problem
mehmetem
PostPosted: Fri Jul 29, 2011 8:25 am     Reply with quote
Hi All,
I have a problem; I could not simulate ex_slave example.
My master code:
#include <16F877A.h>
#device adc=8
#FUSES HS                       //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#FUSES PROTECT                  //Code protected from reads
#use i2c(Master,Slow,sda=PIN_C4,scl=PIN_C3,force_hw)#include <2402.C>
byte gelen=0;
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_psp(PSP_DISABLED);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
   init_ext_eeprom();
   // TODO: USER CODE!!
  gelen= read_ext_eeprom(0x03);
My slave code is
#if defined(__PCM__)
#include <16F877.h>
#elif defined(__PCH__)
#include <18F452.h>
#use i2c(SLAVE, SDA=PIN_C4, SCL=PIN_C3, address=0xa0)
BYTE address, buffer[0x10];
#INT_SSP
void ssp_interupt ()
   BYTE incoming, state;
   state = i2c_isr_state();
   if(state <= 0x80)                     //Master is sending data
      incoming = i2c_read();
      if(state == 1)                     //First received byte is address
         address = incoming;
      if(state == 2)                     //Second received byte is data
         buffer[address] = incoming;
   if(state == 0x80)                     //Master is requesting data
      i2c_write(buffer[address]);
void main ()
int i=0;
   enable_interrupts(INT_SSP);
for (i=0;i<16;i++)
{buffer[i]=0x37;}
   while (TRUE) {}
and my problem: Received data all times 80. Where is my mistake? I could not find. Here is a Proteus picture:
I am sorry for my broken English.
trainee
PostPosted: Fri Jul 29, 2011 8:51 am     Reply with quote
Probably a Proteus problem as it is full of bugs, errors, glitches etc.
You should use real hardware.
If you can't contact a Proteus help forum or the mfr of the simulator.
There are working code examples in the CCS examples folder you might consult, see if they work under Proteus.
mehmetem
Thank you, I solved problem.
PostPosted: Wed Aug 03, 2011 12:57 am     Reply with quote
Smile
trainee
PEDE
PostPosted: Sat Sep 10, 2011 10:29 am     Reply with quote
How did you fix your problem? Thx...
mehmetem
There is not anything, Don't forget pull-up' MY WORKING CODE
PostPosted: Sat Sep 10, 2011 2:12 pm     Reply with quote
BYTE address, BufferTxt[20], buffer[20];
#INT_SSP
         address = incoming;
AND MASTER
  init_ext_eeprom();
 PresetNumber= read_ext_eeprom(0x09);
 if (PresetNumber!=PresetNumberOld)
  CalcPhase();
     yerptr=&(Rpm);
     countL=*(yerPtr);
     write_ext_eeprom(0x07,CountL);
     countH=*(yerPtr+1);
     write_ext_eeprom(0x08,CountH);
     delay_ms(40);
trainee
