the_nes@hotmail.com Guest
Servos.c |
Posted: Tue Dec 04, 2007 2:13 pm |
here is an example for Servos.c Library, I named it as Servo Server
NOTE: u can control a delay, sending parameters from other pic
///////////////////// SServo.c /////////////////////
#include "C:\Program Files\PICC\Projects\SServo\SServo.h"
#include <servos.c>
int1 side; //side { LEFT , RIGHT }
int8 speed; //speed { 0, 1, 2, 3, 4 }
int1 servo; //servo { servo 1, servo 2 }
init_servos(); //initialize servos
while(1) // RUN ALWAYS
speed = 0;
if(pin_B0) //if pin_B0 = 0, Servos on
if(pin_B4) {speed += 4;}
if(pin_B3) {speed += 2;} // pinB4, pinB3, pin_b2 determine the speed, 0b_ _ _
if(pin_B2) {speed += 1;}
if(pin_B1) {side = 1;}
else {side = 0;} // pin_B1, determine the direction, LEFT or RIGHT
if(pin_B5) {servo = 1;}
else {servo = 0;} // pin_B5, pin out, B7 or B6
set_servo(servo, side, speed); //send instruction to servo
stop_servos(); //if pin_B0 = 0, Servos off
//////////// SServo.h /////////////////////
#include <16F874A.h>
#use delay(CLOCK = 4000000)
Posted: Tue Dec 04, 2007 4:07 pm |
sorry
#include <servos.c>
set_tris_b(0b00111111);
speed = 0;
if(input(pin_B4)) {speed += 4;}
if(input(pin_B3)) {speed += 2;} // pinB4, pinB3, pin_b2 determine the speed, 0b_ _ _
if(input(pin_B2)) {speed += 1;}
if(input(pin_B1)) {side = 1;}
if(input(pin_B5)) {servo = 1;}
ss |
Posted: Tue Dec 04, 2007 4:08 pm |
#include <servos.c>
speed = 0;
if(input(pin_B0)) //if pin_B0 = 0, Servos on
arawana
Posted: Mon Jun 23, 2008 4:04 am |
hi..
i want to ask u a question please...
about servo.c library... which 2 pins i have connect to give signal to my 2 servos and i am using PIC16f877a 20Mhz..
and if i want to control more than 2 servo with speed control, can i use this servo.c library? |
davemaster2000
Posted: Thu Jul 28, 2011 10:43 am |
arawana wrote: | hi..
Greetings,
As default in servos.c file, you have the following:
#ifndef LEFT_SERVO_PIN
#define LEFT_SERVO_PIN PIN_D6
#define RIGHT_SERVO_PIN PIN_D7
But, you can change it in your code...
Best regards |
