Servos.c
the_nes@hotmail.com
Servos.c
PostPosted: Tue Dec 04, 2007 2:13 pm     Reply with quote
here is an example for Servos.c Library, I named it as Servo Server Very Happy
NOTE: u can control a delay, sending parameters from other pic
///////////////////// SServo.c /////////////////////
#include "C:\Program Files\PICC\Projects\SServo\SServo.h"
#include <servos.c>
int1 side;       //side  { LEFT , RIGHT }
int8 speed;      //speed { 0, 1, 2, 3, 4 }
int1 servo;      //servo { servo 1, servo 2 }
init_servos();   //initialize servos
while(1)                                 // RUN ALWAYS
      speed = 0;
      if(pin_B0)                          //if pin_B0 = 0, Servos on
         if(pin_B4) {speed += 4;}
         if(pin_B3) {speed += 2;}         //   pinB4, pinB3, pin_b2    determine the speed, 0b_ _ _
         if(pin_B2) {speed += 1;}
         if(pin_B1) {side = 1;}
            else {side = 0;}              //   pin_B1, determine the direction, LEFT or RIGHT
         if(pin_B5) {servo = 1;}
            else {servo = 0;}             //   pin_B5, pin out, B7 or B6
         set_servo(servo, side, speed);   //send instruction to servo
         stop_servos();                  //if pin_B0 = 0, Servos off
//////////// SServo.h /////////////////////
#include <16F874A.h>
#use delay(CLOCK = 4000000)
the_nes@hotmail.com
PostPosted: Tue Dec 04, 2007 4:07 pm     Reply with quote
sorry
#include <servos.c>
set_tris_b(0b00111111);
      speed = 0;
         if(input(pin_B4)) {speed += 4;}
         if(input(pin_B3)) {speed += 2;}         //   pinB4, pinB3, pin_b2    determine the speed, 0b_ _ _
         if(input(pin_B2)) {speed += 1;}
         if(input(pin_B1)) {side = 1;}
         if(input(pin_B5)) {servo = 1;}
the_nes@hotmail.com
ss
PostPosted: Tue Dec 04, 2007 4:08 pm     Reply with quote
#include <servos.c>
      speed = 0;
      if(input(pin_B0))                          //if pin_B0 = 0, Servos on
arawana
PostPosted: Mon Jun 23, 2008 4:04 am     Reply with quote
hi..
i want to ask u a question please...
about servo.c library... which 2 pins i have connect to give signal to my 2 servos and i am using PIC16f877a 20Mhz..
and if i want to control more than 2 servo with speed control, can i use this servo.c library?
PostPosted: Mon Jun 23, 2008 9:56 am     Reply with quote
See this example. It may help.
http://www.ccsinfo.com/forum/viewtopic.php?t=34560&start=22
davemaster2000
PostPosted: Thu Jul 28, 2011 10:43 am     Reply with quote
arawana wrote:
hi..
Greetings,
As default in servos.c file, you have the following:
#ifndef LEFT_SERVO_PIN
#define LEFT_SERVO_PIN PIN_D6
#define RIGHT_SERVO_PIN PIN_D7
#endif
But, you can change it in your code...
Best regards
