Changing baud rates for 2 UARTS
RckRllRfg
PostPosted: Fri Jul 29, 2011 1:57 pm     Reply with quote
The PIC that I am using (16F1947) has 2 UARTS. I know that if I set the baud rate using the set_uart_speed, I have the option of setting a stream. I tend to believe that the stream would be the only way to differentiate between the 2 UARTS.
Other than the stream, is there a way to call a specific UART when using the set_uart_speed function? ie, Is there a set_uart1_speed command?
A quick run down of my situation - I need the ability to change the baud rate based on my DIP switches. So far, I find that the last #use command listed for a specific UART seems to rule, regardless of the conditional statements that I have created. I played with the set_uart_speed at while ago; however, this was before my implementation of streams. This morning, I found that my conditional statements and streams were not doing me a dime of good for the #use rs232 statements. So, I'm thinking that at this point, I need to implement the set_uart_speed command.
I know that there is another posting on this; however, I'm not sure that posting dealt with 2 UARTs.
Thanks -
RckRllRfg
PostPosted: Fri Jul 29, 2011 2:11 pm     Reply with quote
Download the CCS manual and put it on your desktop for easy reference.
You can quickly find out if that function exists or not.
Also, there appear to be two of you in the same group. You shouldn't both
ask the same question in two different threads.
