RckRllRfg
Changing baud rates for 2 UARTS |
Posted: Fri Jul 29, 2011 1:57 pm |
The PIC that I am using (16F1947) has 2 UARTS. I know that if I set the baud rate using the set_uart_speed, I have the option of setting a stream. I tend to believe that the stream would be the only way to differentiate between the 2 UARTS.
Other than the stream, is there a way to call a specific UART when using the set_uart_speed function? ie, Is there a set_uart1_speed command?
A quick run down of my situation - I need the ability to change the baud rate based on my DIP switches. So far, I find that the last #use command listed for a specific UART seems to rule, regardless of the conditional statements that I have created. I played with the set_uart_speed at while ago; however, this was before my implementation of streams. This morning, I found that my conditional statements and streams were not doing me a dime of good for the #use rs232 statements. So, I'm thinking that at this point, I need to implement the set_uart_speed command.
I know that there is another posting on this; however, I'm not sure that posting dealt with 2 UARTs.
Thanks -
RckRllRfg |
