software pwm
tmsenthil03
software pwm
PostPosted: Wed Jun 01, 2011 8:52 am     Reply with quote
http://www.ccsinfo.com/forum/viewtopic.php?t=30139
My question is.........
As brood discussed above . I had test this code, it is working fine. only thing is if any one in the following variable is equal to zero. the output is goes to maximum width.
red_duty = __;
green_duty = __;
blue_duty = __;
I need if these variables are equal to zero, the output will go to zero. How can i make it to Zero , pls give the note.
PostPosted: Thu Jun 02, 2011 2:35 pm     Reply with quote
I modified his code a little bit and it works better now. Here is the revised program:
#include <18F4520.h>
#fuses HS,NOWDT,PUT,BROWNOUT,NOLVP
#use delay(clock=20M)
#define PRELOAD (65536 - 180)
#define RED    PIN_D0
#define GREEN  PIN_D1
#define BLUE   PIN_D2
int red_duty;
int green_duty;
int blue_duty;
int Intcount;
#int_timer1
void timer1_isr()
set_timer1(PRELOAD + get_timer1());
// Interrupt marker for viewing on oscilloscope.
//output_high(PIN_D7);
//delay_us(1);
//output_low(PIN_D7);
if(Intcount == 255)
   Intcount = 0;
   if(red_duty) output_high(RED);
   if(green_duty) output_high(GREEN);
   if(blue_duty) output_high(BLUE);
if(Intcount == red_duty)
   output_low(RED);
if(Intcount == green_duty)
   output_low(GREEN);
if(Intcount == blue_duty)
   output_low(BLUE);
Intcount++;
// Initialize interrupt counter and output pins.
Intcount = 0;
output_low(RED);
output_low(GREEN);
output_low(BLUE);
red_duty = 0;
green_duty = 1;
blue_duty = 2;
//red_duty = 253;
//green_duty = 254;
//blue_duty = 255;
setup_timer_1(T1_INTERNAL | T1_DIV_BY_1);
